We're using C3D 2013 SP2. The survey company we use uses point styles to show the blocks. Say they shoot a catchbasin. Instead of inserting the block, the point shows up as the block.
I did a field check & needed to insert a missed CB. When I inserted the block, the other points that were CBs disappeared. I had to insert the block, copy it the clipboard, undo the insertion & then paste the block in. It did this on other drawings & other blocks.
Any ideas why it would do this?
Mark Green
Working on Civil 3D in Canada
No, I'm inserting the block that the point style uses & is already in the drawing.
Your Name
Your Name
It creates a duplicate point & asks if it should be renumbered. The other points don't disappear though.
Your Name
