Civil 3D Forum
Inserting Points with Attributes
13 REPLIES 13
Message 1 of 14
LIS_Survey
1085 Views, 13 Replies
I am haveing trouble setting up my Civil 3d 2014 to recognize the Attributes it dropes off after the first descption, what am i doing wring can anyone help me i tring adding more columns but it wont let me, i need to add at least 15 colums we are in the pipeline business and have a lot of attributes we use.
13 REPLIES 13
Message 2 of 14
AllenJessup
in reply to: LIS_Survey
Search for " User Defined Property Classifications " in Help. We don't use them but that's supposed to be the way to handle it. You could also create an External Data Reference (XDref) to hold the additional attributes
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 3 of 14
IanMcClain
Out of the Box C3D only uses variations of the PNEZD format;but you can create your own User Defined Properties and create your own custom data columns and a correspoding import format to go with it.
These links may help you get started:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/empty_concept_264-587.htm
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-3E88B795-F2E0-40E8-9F51-E628C3294B9-352.htm
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-B4427B10-15A1-4DF9-A38F-8294EBACFF2-695.htm
Ian McClain
Message 4 of 14
ToddRogers-WPM
Here is a video I created on how to do this...
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 5 of 14
tcorey
in reply to: ToddRogers-WPM
Todd, you had me at att2. 😉
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 14
ToddRogers-WPM
in reply to: tcorey
Haha.  I actually created this for a customer and they needed 10 of them.
Todd Rogers
BIM Manager
Message 7 of 14
rudy5470
I am have trouble with civil 3d displaying all my attributes.
it works when i first imprt them, but after a few days they all disapear.
does anyone have a sulution, reimporting is time consuming verytime this happens, as i have 4,000 points in my file and putting them back in the right layers and using the right symbols takes a long time.
Message 8 of 14
Pointdump
Todd,
That is awesome! Well done!
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 9 of 14
ToddRogers-WPM
in reply to: Pointdump
Thank you sir!!
Todd Rogers
BIM Manager
Message 10 of 14
Thanks, this is a huge problem solver, awesome.
Message 11 of 14
DawnAW
Wow, that was really helpful.  I followed your steps completely.  The only problem is when I import my points, nothing shows up.  Do I have a setting turned off or something?  I am working with Civil 3D 2014.
Message 12 of 14
Pointdump
in reply to: DawnAW
SF,
You'll probably need to post your drawing to figure out what happened. Lots of things to check.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 14
johnstewart1261
Hi SP,
Without diving into you drawing or your data used for import, I will suggest you check a few things that may be causing this.
1st Make sure you don’t have a point that is further out than the data you want to view, For example you may have a point at 0,0. You can also look within the drawing point editor to see if you have points imported and if they are in there select one and zoom to it.
2nd Make sure you are importing data by the way of a survey database and within that database survey settings you have the process line work and insert survey points options checked. You can check your survey database points within the survey tab in prospector to see if those points are within its database and if so you can select the selected points and figures you want to view within the database and then right click on the selected items then select points on the fly out dialog then you will have an option to insert into the drawing. If you select figures and highlight the ones you want to view and then  right click then you will see an option to insert in the drawing.
3rd Make sure prior to import your survey database import routine is using the correct figure prefix library and line code set usually configured within the survey database settings. Within the drawing make sure the Desc key file is the one you want to use and corresponds with the raw coding used in the data you are importing.
4th Something simple like layers all set to frozen or off.
5th Update you point groups and see if they have the correct point style and point label style set for them.
Those are some of the problem I have experienced before hopefully one of these cures your problem.
Good Luck
John
Message 14 of 14
DawnAW
in reply to: johnstewart1261
Thank you for the replies.  The problem was my override settings in the point group.  Once I set the override for the point label style to be checked I got all the labels I expected.  Thanks again.
Rail Community
