are you using the regular insert command? Or the map image insert? Are the
georeferenced?
Just curiosity.
Sorry, nothing snappy here to say.
"Keith" wrote in message
news:5424792@discussion.autodesk.com...
Working with Adesk, which really didn't give us any good solutions and
other person in our company, we found a fix to the images not being
inserted correctly. In C3D, change the drawings settings (in the C3D
workspace palette) from feet to meters, then use the map > image > insert >
they come in correctly. This works for us cause our images are in meters,
then we either scale them or do a conversion to get into feet.
Hope this helps someone else!
Keith
If you get to the end of your rope, tie a knot and hang on.
Franklin D. Roosevelt
