I am working on an existing Pipe Network. I have a location where I have already placed a pipe and filled in the correct parameters for this pipe. But I realize now that there is a concrete headwall near the end of the pipe. So I was trying to insert the structure at the midpoint of a line I have created for OSNAP reasons so it would create the structure at the specified location. The problem is when I move the structure to create at this location, the "Break Pipe Marker" goes away and only shows when I am at a different location along the pipe. So I wanted to see if there was a command or feature to use to tell the software I want to place this structure at a specified location along this one section of pipe.
I wanted to see what my options were. I know I can grab one end of the pipe and move it to the location and then add the structure and pipe from there. But I did this insertion under different circumstances and it broke the pipe into 2 sections while still keeping the same and adding a (1) after it, which is pretty helpful when reading printouts and showing that this is actually one pipe instead of 2 pipes.
Any feedback would be appreciated.
Thanks!
Solved by Joe-Bouza. Go to Solution.
Your Name
Your Name
I was not fully sure how you meant RANDOM insert. But I did try the station offset from the alignment and while it placed the structure at the desired location, it did not break the pipe. So I am unsure of this structure having some type of interference issue or the headwall blocking the pipe? Or does it know that the pipe goes directly through the structure? I heard from another user that you have to have 2 segments of pipe whenever you place a structure along the pipe? Is that correct? So confused now.......
I got it. I placed my structure at the midpoint of the pipe.
Then I selected the structure and chose the station offset command as recommended and when I entered the correct offset numbers it moved the structure to the correct location. Although I have 2 segments of pipe, the names are the same with one of them having a (1) at the suffix. Thanks for the tip and I will use the transparent commands more often to place pipes and structures along my alignment.
Inerting a structure anywhere along a pipe (randomly) when you see a gliph will yield two new segments of pipe. So "randomly" insert the structure anywhere along the pipe them move with the transparent commands
Your Name
Your Name
Your Name
Your Name
