Civil 3D Forum
Insert Structure in Pipe Network
7 REPLIES 7
Message 1 of 8
clemay
2125 Views, 7 Replies
I am working on an existing Pipe Network.  I have a location where I have already placed a pipe and filled in the correct parameters for this pipe.  But I realize now that there is a concrete headwall near the end of the pipe.  So I was trying to insert the structure at the midpoint of a line I have created for OSNAP reasons so it would create the structure at the specified location.  The problem is when I move the structure to create at this location, the "Break Pipe Marker" goes away and only shows when I am at a different location along the pipe.  So I wanted to see if there was a command or feature to use to tell the software I want to place this structure at a specified location along this one section of pipe.
I wanted to see what my options were.  I know I can grab one end of the pipe and move it to the location and then add the structure and pipe from there.  But I did this insertion under different circumstances and it broke the pipe into 2 sections while still keeping the same and adding a (1) after it, which is pretty helpful when reading printouts and showing that this is actually one pipe instead of 2 pipes.
Any feedback would be appreciated.
Thanks!
C3D 2016 SP3
DELL Precision T3600
Intel Xeon E5-1650 @ 3.20GHz
NVIDIA QUADRO 4000 Dual Monitor
32 GB RAM / Win7 Pro 64-bit
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: clemay
insert random then snap to your location. Or make alignment from network and use the transparent commands to station
Joe Bouza
Message 3 of 8
clemay
in reply to: Joe-Bouza
I was not fully sure how you meant RANDOM insert.  But I did try the station offset from the alignment and while it placed the structure at the desired location, it did not break the pipe.  So I am unsure of this structure having some type of interference issue or the headwall blocking the pipe?  Or does it know that the pipe goes directly through the structure?  I heard from another user that you have to have 2 segments of pipe whenever you place a structure along the pipe?  Is that correct?  So confused now.......
C3D 2016 SP3
Message 4 of 8
clemay
in reply to: clemay
I got it. I placed my structure at the midpoint of the pipe.
Then I selected the structure and chose the station offset command as recommended and when I entered the correct offset numbers it moved the structure to the correct location.  Although I have 2 segments of pipe, the names are the same with one of them having a (1) at the suffix.  Thanks for the tip and I will use the transparent commands more often to place pipes and structures along my alignment.
C3D 2016 SP3
Message 5 of 8
clemay
I am still interested in what the "insert random then snap to your location" means exactly. I though maybe after I invoked the structures only with my structure, I would right click and choose "random" and it would let me pick a point along the pipe. but that was not what you were trying to inform me of. So just wanted to learn that part. Thanks!
C3D 2016 SP3
Message 6 of 8
Joe-Bouza
in reply to: clemay
Inerting a structure anywhere along a pipe (randomly) when you see a gliph will yield two new segments of pipe. So "randomly" insert the structure anywhere along the pipe them move with the transparent commands
Joe Bouza
Message 7 of 8
clemay
got it. that's what I did. I placed it at the midpoint of the pipe since it recognized the pipe and was able to break it at that point. Then I moved it via the transparent commands. Worked Perfectly. Thank you 'SO much....lol
C3D 2016 SP3
Message 8 of 8
Joe-Bouza
in reply to: clemay
I know sometimes its hard to see the trees through the forest 🙂 HTH
Joe Bouza
Rail Community
