I have Infrastructure suite 2012 & 2013. After installing and uninstalling some antivirus product demos my C3D/Map/Autocad crashes when I open drawings so I want to repair my installs. Under installed apps in Control Panel there are about 23 applications installed by each version of Infrastructure suite. Which apps do I need to repair? I've tried repairing C3D, Map and Autocad but continue to have problems. It is possible that one or more of the other apps is the problem but I don't know. What should we do when things go bad?
Tech support says I'll have to uninstall and reinstall everything. There is a utility to automate this for Design Suite but not Infrastructure Suite. Thus I will have to manually uninstall about 50 apps between the 2 suites.
Pray you don't ever have to repair your installation of Infrastructure Suite.
