I have one corridor with several baselines. I have asked it to generate a corridor surface but it has left out several baselines from the surface. I have ruled out assemblies. I am not sure what is going on. I am also umable to get feature lines from this portion of corridor as well. The corridor builds just fine and I can see what the daylight lines are etc. What's going on. Yes I have audited the drawing.
Thanks!
Here are a couple questions for you about the surface.
Have you created a boundary? If so you can see if removing the boundary and adding it helps.
Have you preformed any edite? deleting triangles? I have seen edits in one area completely bug out another area of the drawing if it is all in 1 corridor even though the corridor looks good the surface still bugs.
Craig
Craig, thanks for the suggestions! Although I had tried this a couple of times already, removing and re-adding the boundary this time did the trick. When I removed and re-added the boundary previously, it was prior to my performing an audit which fixed some errors. I guess it just took doing that again once the errors were fixed which hadn't occured to me.
