I am working on a project where I need to bring in multiple building site files from Revit as .adsk files to one Civil 3D model. The first building always imports just fine. For any building after the first, I get the following message:
"The selected file contains a definition of a building site that is already in use."
"What would you like to do?"
"Update the definition of the existing building site (cancel the import and use the selected file to update the definition of the existing building site.)" - THIS OPTION REPLACES THE FIRST BUILDING WITH THE NEW BUILDING I HAVE SELECTED
"Browse to another file (display the file browse dialog to select a different file.)" - THIS DOES NOT HELP, AS NO OTHER FILES IMPORT, EITHER
My team and I have tried every we can think of including the following (see attached):
We are worried that this is a bug. All suggestions welcome.
What if you were to link the multiple building sites into one .rvt project before exporting the building site?
I haven't tested this, but it's worth a try.
Tim
Can I ask if you ever resolved this issue? We are having a similar issue. I have three separate buildings on a phased site, but I would like to show all three of them for the final rendering. Can you point me in the right direction? We have tried having all three buildings in one revit site file and we have not been able to overcome this issue. We have also tried changing the project name but it has something to do with the definition of the site. Thanks.
I don't know if this will work, but it might be worth a shot. If you have the full building design suite, use the IFC out process in Revit. Import into AutoCAD Architecture, then xref the ACA dwg into Civil 3D. I've used the IFC process between Revit and ACA with success in the past.
My work around was to create three separate drawings and then xref those into the main job. Not elegant, but it worked. Thanks.
