I have copied the properties from the line into excel spread sheet and created a point file with lat longs and saved it as a .csv file. Then when i proceed to import this into CAD I get error message saying no points were transfered from source. I cannot seem to figure out my problem.
You'll need to create a new Point File format with LAT and LONG as the file format.
Rick Jackson
Survey CAD Technician VI
This might get you in the right direction
Rick Jackson
I tried using both the default CAD Lat Long format and created a new one of my own. I get the green arrow saying it is going to work then i get error message when I try to import them.
Rick Jackson
Please run _MAPIMPORT on my attachment: is it what you're after, sir?
How do I run the mapimport command? Do I run this on your shape file or which file? My point is in Lat Long not northings and eastings and thats the only things Im getting options for.
I am using Lat Long DECDEG and thats when I am getting the error message.
This is one way I did it. Used LL84 since I didn't know what system. BTW. I'm getting the same results as you in Civil 3D, tried a couple of formats. It just doesn't like the file.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
You should simply type MAPIMPORT at the command prompt (if you haven't one, press CTRL-9).
To load the full PENZD object data, do as follows:
Much better. I got it to insert so you don't have to use the link.
Allen
Allen Jessup
