AutoCAD Civil 3D General
Member
Message 1 of 11 (318 Views)
Importing MX Highway design to Civil 3D
318 Views, 10 Replies
09-02-2013 12:22 PM
Hi all
I'm new to this forum so any help with my query would be greatly appreciated.
I am looking into switching to AutoCad Civil 3D from MxRoads. Up to now I have been using Mx and have a large back catalogue of roads work all in MX formats, Input files, Genios etc.
Given that Mx is string based and Civil 3D appears to be section based, I'm wondering if when you import a genio created in Mx, is there a way to "link" a carriageway string to the master string, without having to recreate the alignment from scratch. If I needed to do a quick change to a vertical alignment or a road widening I want to be able to do without reinventing the wheel!!! I need to ensure that the program can recognise the relevant cway string that matches the Master string.
If any other information is need or my query is unclear please let me know
S
*Expert Elite*
neilyj
Message 2 of 11 (314 Views)
Re: Importing MX Highway design to Civil 3D
09-02-2013 12:36 PM in reply to: oreillysea
not sure if the object intelligence is maintained via GENIO as it is when creating objects natively in C3D. I'm guessing that you are aware of the GENIO converter available on the subscription site which imports various objects and although it has limitations I'm not sure how it handles complex geometry strings
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Member
Message 3 of 11 (275 Views)
09-03-2013 02:10 AM in reply to: neilyj
Thank you for your response. I haven't switched over to C3D as of yet I am looking into it but need to get all the pros and cons before talking to jump, as I'm currently Mx I need to be sure that they are compatible, within reason, any opinions on the matter would be appreciated.
Sea
*Expert Elite*
neilyj
Message 4 of 11 (269 Views)
09-03-2013 03:23 AM in reply to: oreillysea
You may be as well downloading the trial version and using it for 30 days although I'm not sure if the GENIO converter is available for the trial and the Civil 3D learning curve can be VERY steep.
XML files can also be imported to Civil but not sure if MX can export them.
neilyj
*Expert Elite*
mikeevans
Message 5 of 11 (261 Views)
09-03-2013 05:09 AM in reply to: oreillysea
I have not used it from Civil3d to MX and have been told there is an incorrect statement in the exported text file but I have used it in the other direction.
Intelligence for IP / VIP in Profiles and alignments is not maintained (dragging will not adjust the alignment / profile accordingly). However it will bring data in and allow you to edit it, delete an element & recreate over it to obtain inteligence where required.
You will be able to import all design alignments, profiles & feature strings as well as 3d geometry. I use this feature a lot as other companies we interact with run MX.
Edit: Oh you wont get a corridor object model, you will need to model that manually from the designed alignments & profiles / 3d geometry.
I reconmend not using on live projects, continue in MX only swap to Civil3d for new projects using existing data.
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
*Expert Elite*
neilyj
Message 6 of 11 (254 Views)
09-03-2013 05:13 AM in reply to: mikeevans
Although a major flaw I encountered recently was when bringing in an existing topo via GENIO there were a lot of single point spot level strings that the GENIO converter couldn't handle and so were ignored, thus compromising the EGL model.
neilyj
*Expert Elite*
mikeevans
Message 7 of 11 (216 Views)
09-04-2013 05:30 AM in reply to: oreillysea
I've seen this many times before too and would only use genio import for alignments, profiles & other strings from moss / mx.
The best methiod of importing any surface model is to generate triangles and export a dxf / dwg file. use these for the definition then add any string data to it.
Mike Evans
*Expert Elite*
neilyj
Message 8 of 11 (209 Views)
09-04-2013 05:45 AM in reply to: mikeevans
Definitely but any GENIO files we get have been generated by a 3rd party and we are unlikely to be provided with any further data which is very annoying.
neilyj
Member
Message 9 of 11 (184 Views)
09-05-2013 01:54 AM in reply to: neilyj
Thank you for your responses,
From the feed back I'm getting here it seems that the transferring from Mx to C3D is not as seamless as hoped. I am wondering what in ye're opinion would be the better option. I would be hoping to incorporate drainage etc into my models and I do note that the interface of C3D seems more graphically based, Up to now however I have been using Mx and do like the control Input files provide, especially in transferring information and the dual working that can happen on the same alignment at the same time.
Any advice ye could send my way would be greatly appreciated.
Thanks again
Sea
*Expert Elite*
neilyj
Message 10 of 11 (178 Views)
09-05-2013 02:19 AM in reply to: oreillysea
Ahhhh...input files; a relic from the old UNIX days of MOSS...I remember them well and quite liked the way they could be replayed actually.
No such feature in Civil though and everything is wizard/graphically based unless you are a wizard at .NET in which case much of the objects are exposed for programming etc (but this is way beyond me although much could presumably be automated but it would take a long time to code it I guess...).
Is there a compelling reason to change from MX - if it ain't broke don't fix it. As I said previously the learning curve is very steep and adequate training is an absolute must to flatten that curve a little..
neilyj
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
