Active Contributor
M_RR
Message 11 of 16 (110 Views)
Re: Importing Data
02-18-2013 09:55 AM in reply to: M_RR
Well, we cross checked the point x and y value and they should fit... we used ArcGIS to check the zone and, on the NAD83, the coordinate " make senses " for the zone...
Valued Mentor
IanMcClain
Message 12 of 16 (108 Views)
Re: Importing Data
02-18-2013 09:57 AM in reply to: M_RR
GPS is a pretty loose term. It stands for Global Positioning System, but the way you are using it is in reference to a reciever unit. The coordinates that you have in xyz could be anything, state plane, assumed, etc. It depends on what system the field software was set to use or export to.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
Valued Mentor
IanMcClain
Message 13 of 16 (101 Views)
Re: Importing Data
02-18-2013 10:11 AM in reply to: M_RR
Well, I'd verify that the drawing has the appropriate state plane system set under drawing settings and try importing again. Can you post the files?
-Ian McClain
Active Contributor
M_RR
Message 14 of 16 (99 Views)
Re: Importing Data
02-18-2013 10:15 AM in reply to: M_RR
Yeah sure.
But now am thinking that the problem might come from the hypsometric data. The shape file was created with ArcGis 9.3.1. Maybe there is a comptability issue with C3D-2013 ?
Because, when we use the ArcMap tools, the point and the hypso falls in good agreement !! (in MTM-6 ).
Valued Mentor
KirkNoonan
Message 15 of 16 (84 Views)
Re: Importing Data
02-18-2013 11:32 AM in reply to: M_RR
Civil 3D doesn't always speak the same coordinate zone language as ArcMap. You might need to manually set the cooridinate system when you import the shapefiles into Civil 3D. If you don't see the right zone appear when you import, click on the edit coordinate systems button and choose the right one.
PorterCAD
Message 16 of 16 (63 Views)
Re: Importing Data
02-18-2013 02:28 PM in reply to: KirkNoonan
After you've verfied the metadata and the coordinate systems are correct you must then create the two files (an Ian spoke of in an earlier post) and then query them together using the Map 3D tools.  To better understand this here is a short (30-minute) video that shows you how to import and query in hyspo data, image data, DGN data, and shape files into one drawing and have them all come into the correct coordinate system.  Sorry but I made this video for our clients here in the Austin, TX, area but the concept should work for any part of the country.
http://dccadd.com/dirt/?p=1448
Jason
Jason Porter
Enceptia Technical Advisor & Civil Solutions Blogger
http://enceptia.com/author/jporter/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
