Okay, there is a good possibility that I am over looking something...but is there not a way to import an AutoCAD *.dwg file into Civil 3D?
Basically, I have set up a template with the required blocks and other information; I want to keep that information loaded and available no matter which drawing I open. I realize that I can just open a .dwg in Civil; but I do not want to lose or have to reload my blocks, etc. everytime I work on a customer drawing.
Are you even able to import a .dwg into a Civil template?
Try inserting your template drawing with your blocks and such into the correct civil 3d .dwt template file, saving and closing.
The template is fine; I just want to import a customer drawing into the 'template'.
Try:
1. Open blank drawing from your civil 3d template with blocks, styles, settings, etc.
2. Insert customer drawing
3. Save and close file.
Let me know if this works.
@Citadel2012 wrote:
Try:
To add a little more, After you insert the customers dwg with the insert command, explode it once so its not a block.
Save the template file with a new name, I.E. Customer1.dwt. and place it in the same folder as your other dwts.
