Civil 3D Forum
Import points from a file
7 REPLIES 7
Message 1 of 8
731 Views, 7 Replies
In Civil 3d 2010 I got an error saying "Error parsing value line 1 ect and invalid characters.
I'm importing a point.xyz file using PNEZD (space delimited). The file seems to look ok.
7 REPLIES 7
Message 2 of 8
Jason.Hickey
Can you post a part of the point file? You say it's an XYZ file, which typically doesn't have point numbers (the P in PNEZD) or descriptions (the D) - if it's truly a easting, northing, elevation file (XYZ) then you'll need to change to that format to get it to import - if it's looking for a component that's not in the file format, then it won't work.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
Message 3 of 8
antoniovinci
in reply to: Jason.Hickey
I guess you should open your point list in Notepad, and erase the first line probably containing the field names...
Message 4 of 8
neilyj666
It would be useful if C3D could read files which still had header information in the first line e.g. if the first line didn't fit the template for PENZD or ENZ or whatever, then just ignore the line and process the next one
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 8
Jason.Hickey
in reply to: neilyj666
You can ignore commented lines in the point file format - and the new point file import dialog parses the file for you for a visual confirmation of the format.
Jason Hickey
Autodesk, Inc.
Message 6 of 8
rdawson
I would be glad to take a look if you will paste a few lines of your file.
Message 7 of 8
Deleting first line seems to work Thanks to everyone
Message 8 of 8
neilyj666
Thanks for this - never really noticed that option before so I just put a # in front of the No. in my point file and the line was ignoredSmiley Happy
Rail Community
