AutoCAD Civil 3D General
Valued Mentor
IanMcClain
Message 1 of 11 (655 Views)
Accepted Solution
Import Survey Data default point group styles
655 Views, 10 Replies
05-03-2012 10:41 AM
When you use the Import Survey Data wizard it automatically creates a point group that goes to the top of the list. This used to be created with a standard point style and description, but something has changed and I'm getting a different symbol and label that I definitely don't want as the default. I would think that this would be controled by the CreatePointGroup settings, but that isn't working for me. I can't find any other settings that would override or control this. Any ideas?
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
*Expert Elite*
Sinc
Message 2 of 11 (644 Views)
Re: Import Survey Data default point group styles
05-03-2012 12:53 PM in reply to: IanMcClain
We typically use Description Keys to control these Styles, not the Point Group.
Sinc
Valued Mentor
IanMcClain
Message 3 of 11 (641 Views)
05-03-2012 01:01 PM in reply to: Sinc
So do we, but we also use some pre-defined point groups to control the style for our countrol points, which are always created within a predefined point range but do not have a standard description and the symbol used can vary depending on what the end product is.
It's kind of a moot point since I just move the auto created point group to the bottom of the list anyway. I'm just curious what is telling it to create point groups with a back flow preventer as the style :\
-Ian McClain
*Expert Elite*
Sinc
Message 4 of 11 (638 Views)
05-03-2012 01:05 PM in reply to: IanMcClain
There are lots of problems like this in C3D.  As another example, if you use a suffix or prefix in an Object Layer setting, newly-created layers do not copy the Plot Style set in the source layer.  It's one of those many user-unfriendly items in C3D that don't get fixed, even though we have new incompatible releases every year.
Sinc
Valued Mentor
IanMcClain
Message 5 of 11 (573 Views)
08-24-2012 11:19 AM in reply to: Sinc
I figured it out:
Go to Settings > Point > Edit Feature Settings > Defualt Styles. If they are set to none, change it to something acceptable, and then change it back to none. It seems the survey database import will not set the point group it creates to <none> so it remembers whatever that last default was.
-Ian McClain
mikepo
Message 6 of 11 (440 Views)
03-29-2013 11:37 AM in reply to: IanMcClain
I'm having the same issue and it just recently started happening.
When I import points from a survey database, the point group it creates has a drill point style with north-east label.
Not sure if the issue cropped up when we implemented 2013 from 2012 or somewhere a setting got changed, but really need to figure this one out. :smileymad:
Mike Porter
www.ppeng.com
Civil3D 2014 SP1
Win 7 Professional - 64-bit
HP Z400
Xeon W3550 @ 3.07Ghz
24GB of RAM
Nvidia GeForce GTX 760
Valued Mentor
IanMcClain
Message 7 of 11 (436 Views)
03-29-2013 11:56 AM in reply to: IanMcClain
Does the above solution work for you in 2013? If not, try setting the CreatePointGroup command with some acceptable default styles.
-Ian McClain
mikepo
Message 8 of 11 (432 Views)
03-29-2013 12:03 PM in reply to: IanMcClain
No. That's what I tried first.
I also checked the "Create point group" command settings to make sure it was correct there.
I also opened my template and created a new point group. It came up with a default style of DRILL POINT and label style of NORTH-EAST, so I changed it to the correct styles and created a new group. I then deleted that point group, saved my template and then tried importing points again. Still came up with the DRILL POINT and NORTH-EAST styles.
I'm suspecting now that it may be because we saved our 2012 template in 2013 rather than using a new 2013 template and importing our custom setttings into it.
I know there are a couple other issues that doing that causes.
Mike Porter
www.ppeng.com
Civil3D 2014 SP1
HP Z400
24GB of RAM
mikepo
Message 9 of 11 (420 Views)
03-29-2013 01:54 PM in reply to: IanMcClain
Just tried it using the OTB 2013 Imperial template and it works fine.
There's something missing when you save an older version template drawing to a newer version.
Mike Porter
www.ppeng.com
Civil3D 2014 SP1
HP Z400
24GB of RAM
Valued Mentor
IanMcClain
Message 10 of 11 (418 Views)
03-29-2013 01:56 PM in reply to: IanMcClain
Interesting. What happens if you import all styles and settings into the fresh template? Does the problem come back?
-Ian McClain
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
