AutoCAD Civil 3D General
*Expert Elite*
klugb
Message 1 of 4 (323 Views)
Accepted Solution
Import Styles corrupt layer
323 Views, 3 Replies
03-07-2013 09:32 AM
Can someone who has a specific layer assigned for the water drop routine verify if you get the same results.
If I take a file that has the layer assigned (C-TINN-WSHD)  and import my template using the "Manage-Import styles"  it corrupts the layer to (AcDbObjectId::kNull), then when I save the drawing and reopen it's reset to layer (0).
Pretty obvious but this only happens when "Import Settings" is toggled on, but it shouldn't be corrupting the layer if on.
Both files have the same settings and layers in each, so it's not looking for something that isn't there.
See Image.
EDIT: Just a heads up, I was able re-create this with “_AutoCAD Civil 3D (Imperial) NCS.dwt”
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP1)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
*Expert Elite*
tcorey
Message 2 of 4 (285 Views)
Re: Import Styles corrupt layer
03-07-2013 12:16 PM in reply to: klugb
Sorry to say, I can reproduce the error. Dang it.
Bug report!
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
*Expert Elite*
klugb
Message 3 of 4 (281 Views)
03-07-2013 12:26 PM in reply to: klugb
Yea, thought I was going nuts. Kept getting notes that was set to layer 0 but the template has been assigned to thst layer for a long time.
Already submitted to ADSK.
THANKS
Bruce Klug
Win 7 Pro, 64-bit
*Expert Elite*
klugb
Message 4 of 4 (259 Views)
03-08-2013 07:20 AM in reply to: klugb
Confirmed by Autodesk and reported to development.
Bruce Klug
Win 7 Pro, 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
