Civil 3D Forum
Import Point with Long and Lat
1 REPLY 1
SeattleCADD
505 Views, 1 Reply
Hello All,
I don't know what is wrong with my point format, but could not import. I have attached here the point file that I wanted to bring in.
Point number, Lat, Long, Pole tag, Dams_ No, Height, Yr Installed, QSEC.
I have created a new point format with Point number, lat, long and the last 5 colums i created with User-Defined (data type is String)
When I import the point, it said doesn't match with point format. Could you please take a look and let me know what i did wrong?
Thank you very much.
1 REPLY 1
in reply to: SeattleCADD
It looks like your latitude and longitude are in decimal degrees. If they are, you need to choose the column name "DECDEG Latitude/Longitude".
I have never tried using the "User defined" option. I've alway created a UDP, but this may have been overkill. I will look into this. Thanks
Regards
Rail Community
