Hello All,
I wanted to import a shape file from GIS, but all contours elevations are 0. The attribute data on contours have ID elevation. How do I querry those ID elevation to the contours?
Thank you!
Dennis
Solved by Joe-Bouza. Go to Solution.
Here is one way from a few years ago.
http://map3d.wordpress.com/?s=contours
Hi Dennis
have you tried the surface panel>>>surface from GIS data? Is skips the whole import object data bla bla bla. Shp directly into surface.
@Joe-Bouza wrote:Hi Dennis
Joe,
I make the kids walk to school for a while then when they do ride the bus they are more appreciated of it. 🙂
