Civil 3D Forum
Import GIS then export to Autocad
2 REPLIES 2
dmmeehan
343 Views, 2 Replies
I have just had a coworker import some GIS data in shp format. Then had him exporttoacad so that I can use the file in Vanilla autocad. When I open the file, there is nothing there. How can I get this data into Vanilla autocad?
2 REPLIES 2
ToddRogers-WPM
in reply to: dmmeehan
If you import (MAPIMPORT) a .shp file, it is already linework.  You should not have to export it back out to AutoCAD.  If you do a FDO connection with a .shp file, you can click the Maps button and select Save as AutoCAD Drawing.
Todd Rogers
dmmeehan
in reply to: ToddRogers-WPM
That worked like a charm...
I had made the FDO. Then tried an export to acad.
Rail Community
