Civil 3D Forum
Image quality dreadful in 3DS Max design compared to Civil 3D
3 REPLIES 3
neilyj666
627 Views, 3 Replies
I've got a georeferenced jpg that looks great in Civil 3D but the image quality is dire when draped in 3DS Max Design - see screenshots.
I've draped the image in Civil 3D and it looks as good in 3D as it does in Plan view
How can I resolve this problem?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
MikeEvansUK
in reply to: neilyj666
This is probably due to the render material. try using the image as bump maps etc as well.
Apply the material and map it to the surface using an ffd box so you can adjust it to suit, forgive me it has been about 10 years since i used Max in anger.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
neilyj666
in reply to: MikeEvansUK
Thanks for this - not sure what it means though...:)
neilyj666
The solution - thanks to Florian at Autodesk support - to this is
Change the texturesize of the viewport by going to Configure --> Display Performance. Here you should change the texturesize to i.e.: 4048.
Then reboot 3dsMax.
Rail Community
