I've got a georeferenced jpg that looks great in Civil 3D but the image quality is dire when draped in 3DS Max Design - see screenshots.
I've draped the image in Civil 3D and it looks as good in 3D as it does in Plan view
How can I resolve this problem?
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
The solution - thanks to Florian at Autodesk support - to this is
Change the texturesize of the viewport by going to Configure --> Display Performance. Here you should change the texturesize to i.e.: 4048.
Then reboot 3dsMax.
