I'm having the exact same issue.
Double-click seems to work to get to the Adjust properties. However, clipping doesn't seem to work and I'm unaware of another avenue for executing this command.
Basically, what happens is... Select an image, right-click, popup menu with image editing commands. Clicking any of the commands in the Image fly-out do absolutely nothing. No command line promting, no indication or command echo that a command is even executed.
For good measure, I tried to do the same in Land Desktop, and came to the same result (or lack thereof).
Working in C3D 2007, SP3, XP SP2, Raster OE installed, with SID images.
Anyone have any ideas at all?
Edit: Duh! I tried IMAGECLIP and it worked. First thing in the AM may not exactly be the best time to post on the boards.
However, I wonder why the menu commands no longer appear to work...
Message was edited by: Paul Richards
