Anyone know how to do this? I'm hoping to come up with a radial bearing expression that I can add to a label style. In order to label bearings, I need the expression to different things for different situations. I don't see IF THEN in the list of commands in the expression creator box. Any ideas?
Thanks!
Paul
Just IF (test,true_val,false_val)... You need to use nested IF statements.
It would be nice to have a Select Case Statement
Thanks, that is working. What about IF/AND expressions? In this case, I'm trying to determine Quadrants, so I need to be able to determine if Both the northing and easting are positive, negative, or mixed.
Mark Green
Working on Civil 3D in Canada
