neilyj (No connection with Autodesk other than using the products in the real world)
Solved by Joe-Bouza. Go to Solution.
If it was me, I'd use the corridor method as well.
Cheers,
Peter Funk
Autodesk, Inc.
Joe Bouza
Joe Bouza
I added all the other subs to demonstrate the power. You can do it with a general link on the offset node.
I did it with an offset only because i recently discovered how easy it is. the offset assembly is more important if you have to honor baseline stations. A simplified way would be a regular assembly run along your widen alignment and target an inside edge alignment, FL or pline or from the inside out either way works
Joe Bouza
"..Stopped the Acad process and tried this again and the hatching seem to be following the alignments as expected..."
No, it's not stable Neil.
It will follow it around for a little while, but then it loses its Associative property after a few movements. Try grip-editing the Parent Alignment origin and pull it back a couple hundred feet, etc.,, etc.
Joe Bouza
Joe Bouza
Using my original "Export to AutoCAD" method I could easily use fields to label the widenings with areas, how can I label the widenings using the corridor method?
Joe Bouza
Joe Bouza
Neil
I got to thinking about the area query and realized that Parcels may be an option. All you need to do is put the alignments in a site and you get a robust hatch and area for the widen areas
change the ext to dwg
Joe Bouza
I've tended to stay away from parcels after getting a seriously corrupted drawing and losing a day's work when using 2011.
That said though, I think this parcel method looks like a winner; dynamic and no corridors to build and maintain...:)
Have a Kudo...
I know what you mean, but I think most of the problems come by way of poorly drawn parcels and two alignments should fair ok IMHO
Joe Bouza
