Civil 3D Forum
IS THERE A FREE WAY TO IMPORT TERRAIN DATA?
21 REPLIES 21
Message 1 of 22
w_davis
4005 Views, 21 Replies
Hey,
I have tried using Plex.Earth but it was only a trial, and I was wondering fi there was a free way to import terrain data in AutoCAD C3D 2010?  Thanks Guys.
21 REPLIES 21
Message 2 of 22
mathewkol
in reply to: w_davis
If you can get your hands on DEM information, which is generally pretty easy, there's your terrain data. The ease of obtaining it depends on where it is you need the data.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 22
w_davis
in reply to: mathewkol
Now this may seem like a redundant question but I have never used DEM data before so could you help me understand where I should look for it?
Message 4 of 22
Neilw_05
DEM=Digital Elevation Model. There are several sites that offer them free of charge. The best source for free DEM's is the National Map, sponsored by the USGS, since those DEMs are the most current and highest resolution. A web search should get you the links.
Be aware that the DEM's provided via the National Map are in NED (National Elevation Dataset) format. C3D can read those files but it is not a documented process. You'll want to query the forum for topics about importing NED files.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 22
AllenJessup
Letting us know where you're looking for data would help. I've found assuming that everyone's in the USA can lead one astray.
Allen Jessup
CAD Manager - Designer
Message 6 of 22
w_davis
in reply to: AllenJessup
I am in MN, I am also trying the National Map and using NED data, so the next step in my journey is to figure out how to import this into AutoCAD, and I realize that there are some threads that probably relate to this but if you have any advice on doing that that might save me some time....much appriciated.
Message 7 of 22
brian.strandberg
As it happens, I just wrote a tutorial on importing data from the National Map for my company, and will post it here.  I havn't been able to get input from co-workers yet so use at your own risk, and please forward any suggestions.
This covers importing Terrain Data and Orthophotos.
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
Message 8 of 22
w_davis
in reply to: brian.strandberg
So I download the data from National Map, open it up and find the w001001.adf file and go to open it in AutoCAD and it says invalid DEM file???  What could I be doing wrong?
Message 9 of 22
Neilw_05
Instructions for the process can be found in several posts on the forums. Please don't expect someone to re-write them to save your time doing the research.
WIN 10 64 PRO
Message 10 of 22
brian.strandberg
I'm not sure, it could possibly be a problem with the download I have not had that error.  Check the section in the Civil 3d help and see if the information there can help you.
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-FC6B53E9-A7F7-414F-AC3D-CAF0075...
Message 11 of 22
dasindog
Give this a shot. https://app.blueridgeanalytics.com/topolite/
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Message 12 of 22
w_davis
So in my case, Autocad needed access to the Unzipped file that the data came in, not just the .adf file copy and pasted.  This seems to have worked but is currently loading, only time will tell.
Message 13 of 22
mayottet
I followed your tutorials to the letter, but have been getting data files that have 1000x the number of points you had with your 1/9 arc second file.  This keeps happening with other sites as well.  I am at a loss as to what the problem may be.  I suspect that my bounding box is not being interpreted for some reason and instead I am getting a file for an entire quadrangle.  Any thoughts?
Message 14 of 22
As an alternative, and if you have it, you can import the DEM into Infraworks and then export out a .imx file and then import that into C3D. No need to set coordinate systems or worry about elevation issues.
HERE is my write up on it using Autodesk Infrastructure Modeler which was rebranded as Infraworks.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 15 of 22
fcernst
in reply to: BrianHailey
Is there any free data with Breaklines for floodplain modeling?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 16 of 22
BrianHailey
in reply to: fcernst
Almost all of the data I've seen has been in DEM format and not breakline information. Every once in a while I'll find contour data but that's pretty rare.
GEI Consultants
My Civil 3D Blog
Message 17 of 22
mayottet
in reply to: dasindog
Brian:
There was no post of your NED download tutorial, as noted in your message.
Message 18 of 22
fcernst
Why can't Civil 3D import and convert the LL84 NED datasets to Imperial coordinate systems on its own by now?
Civil 3D seems so neglected.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 19 of 22
neilyj666
if it ain't 360 or Apple based, then nothing new or improved/enhanced is ever added; at least that is the impression that I get....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 20 of 22
BrianHailey
in reply to: mayottet
@mayottet wrote:
Brian:
The word "HERE" had a hyperlink to the article.
Here is the link: http://civil3dplus.wordpress.com/2012/11/20/dem-files-in-civil-3d-take-2/
GEI Consultants
My Civil 3D Blog
Rail Community
