I can open a drawing but when I click on the model tab this error pops up and the program closes.
Any help would be appreciated.
C3D w/ multiworx. SP1 installed
Mike,
The error does not come up when I use tilemode but it also doesn't fix the problem either.
It happens on every drawing and on new drawings with different templates.
I have done a factory reinstall and that also didnt fix the issue.
I am using C3D 64 bit on Windows 8
I Re-installed windows and reinstalled Civil3d, not sure it was neccessary but I couldn't get any other solutions.
The same error has come back. It is not drawing related it happens with all drawings I open.
Any help?
This is definitely a problem with Multiworx. Leica has been very slow to patch this program and give us something usable. Please use the bug reporting tool in Multiworx and report the problem. The more attention it gets, the more likely it will be fixed.
How about trying our latest version? This was fixed quite some time ago (several versions back). If you install the latest version of MultiWorx 1.0.2 you should no longer have problems
