Civil 3D Forum
INTERNALERROR: !AcQuoI)IEntity.cpp@71S0: eWasOpenForWrite
8 REPLIES 8
Message 1 of 9
smcgeomatics
472 Views, 8 Replies
I can open a drawing but when I click on the model tab this error pops up and the program closes.
Any help would be appreciated.
C3D w/ multiworx. SP1 installed
8 REPLIES 8
Message 2 of 9
MikeEvansUK
in reply to: smcgeomatics
Version? OS?
Not sure what multi works is.
Are you using a shipped template? May be a corrupted one.
Does it happen with other files? Try using tilemode command instead, does this work or give same error?
If so perform factory reset or reinstall.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 3 of 9
smcgeomatics
in reply to: MikeEvansUK
Mike,
The error does not come up when I use tilemode but it also doesn't fix the problem either.
It happens on every drawing and on new drawings with different templates.
I have done a factory reinstall and that also didnt fix the issue.
I am using C3D 64 bit on Windows 8
Message 4 of 9
Jeff_M
Which C3D? 2012, 2013, 2014, other?
Message 5 of 9
smcgeomatics
in reply to: Jeff_M
2014
Message 6 of 9
smcgeomatics
I Re-installed windows and reinstalled Civil3d, not sure it was neccessary but I couldn't get any other solutions.
Message 7 of 9
smcgeomatics
The same error has come back. It is not drawing related it happens with all drawings I open.
Any help?
Message 8 of 9
This is definitely a problem with Multiworx.  Leica has been very slow to patch this program and give us something usable.  Please use the bug reporting tool in Multiworx and report the problem.  The more attention it gets, the more likely it will be fixed.
Message 9 of 9
How about trying our latest version? This was fixed quite some time ago (several versions back). If you install the latest version of MultiWorx 1.0.2 you should no longer have problemsSmiley Wink
Rail Community
