AutoCAD Civil 3D General
Active Member
Message 1 of 9 (216 Views)
INTERNALERROR: !AcQuoI)IEntity.cpp@71S0: eWasOpenForWrite
216 Views, 8 Replies
11-22-2013 04:56 PM
I can open a drawing but when I click on the model tab this error pops up and the program closes.
Any help would be appreciated.
C3D w/ multiworx. SP1 installed
*Expert Elite*
mikeevans
Message 2 of 9 (187 Views)
Re: INTERNALERROR: !AcQuoI)IEntity.cpp@71S0: eWasOpenForWrite
11-23-2013 08:35 AM in reply to: smcgeomatics
Version? OS?
Not sure what multi works is.
Are you using a shipped template? May be a corrupted one.
Does it happen with other files? Try using tilemode command instead, does this work or give same error?
If so perform factory reset or reinstall.
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Active Member
Message 3 of 9 (175 Views)
11-24-2013 02:21 PM in reply to: mikeevans
Mike,
The error does not come up when I use tilemode but it also doesn't fix the problem either.
It happens on every drawing and on new drawings with different templates.
I have done a factory reinstall and that also didnt fix the issue.
I am using C3D 64 bit on Windows 8
*Expert Elite*
Jeff_M
Message 4 of 9 (170 Views)
11-24-2013 02:46 PM in reply to: smcgeomatics
Which C3D? 2012, 2013, 2014, other?
Active Member
Message 5 of 9 (163 Views)
11-24-2013 02:54 PM in reply to: Jeff_M
2014
Active Member
Message 6 of 9 (122 Views)
11-28-2013 11:01 AM in reply to: smcgeomatics
I Re-installed windows and reinstalled Civil3d, not sure it was neccessary but I couldn't get any other solutions.
Active Member
Message 7 of 9 (88 Views)
12-02-2013 07:31 PM in reply to: smcgeomatics
The same error has come back. It is not drawing related it happens with all drawings I open.
Any help?
Active Member
croberts97
Message 8 of 9 (29 Views)
04-15-2014 01:47 PM in reply to: smcgeomatics
This is definitely a problem with Multiworx.  Leica has been very slow to patch this program and give us something usable.  Please use the bug reporting tool in Multiworx and report the problem.  The more attention it gets, the more likely it will be fixed.
New Member
Message 9 of 9 (21 Views)
04-15-2014 03:11 PM in reply to: smcgeomatics
How about trying our latest version? This was fixed quite some time ago (several versions back). If you install the latest version of MultiWorx 1.0.2 you should no longer have problems:smileywink:
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
