Hi-
I'm working in C3D 2013. When I try to use the "invert clip" option in the IMAGECLIP command, it keeps clipping everyting outside the boundary rather than inside. I've tried both tiffs and jpegs. I've tried attaching the image through the xref manager. I've tried dragging the image into the file. I've also tried just using the CLIP command. It works on my coworker's computer. Just not mine. Is there a system variable or some obscure setting that would affect this?
Thanks so much!
Meredith
If the issue is isolated to your computer and it works using same 2013 version / patches on the same dwgs / images for others configured the same way then you may want to consider resetting your user settings per Autodesk instructions Here.
