Civil 3D Forum
IMAGECLIP Invert clip won't work
1 REPLY 1
mermerCAD
1133 Views, 1 Reply
Hi-
I'm working in C3D 2013.  When I try to use the "invert clip" option in the IMAGECLIP command, it keeps clipping everyting outside the  boundary rather than inside.  I've tried both tiffs and jpegs.  I've tried attaching the image through the xref manager.  I've tried dragging the image into the file.  I've also tried just using the CLIP command.  It works on my coworker's computer.  Just not mine.  Is there a system variable or some obscure setting that would affect this?
Thanks so much!
Meredith
1 REPLY 1
Jay_B
in reply to: mermerCAD
If the issue is isolated to your computer and it works using same 2013 version / patches on the same dwgs / images for others configured the same way then you may want to consider resetting your user settings per Autodesk instructions Here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
