Excellent suggestion Laurie. One caveat, the offset command will not allow a
value of zero, so you'd have to give it a value and then offset the result
back again.
Laurie wrote:
You could use the Offset command on the alignments with an offset of
zero. This will create polylines which should go into ArcGIS and
leave you with the full functionality of your alignments in Civil 3D.
Good one, here's a little lisp to implement it.
(defun C:ALI2PLN ()
(if (/= (setq obj (entsel "\nSelect Alignment: ")) nil)
(command "_.OFFSET" 0.0000000000000001 obj '(0 0) "")
Terry
