Civil 3D Forum
I lost my Right Click options
8 REPLIES 8
Message 1 of 9
Lieblaw
6600 Views, 8 Replies
I'm not sure what happened but I recently lost my Right-Click options showing Select Similar specifically...is there a function key that disables this use or am I partially crazy?  I realize this may be a simple AutoCAD function to fix but you guys are faster than perusing through the book.  Any help will be greatly appreicated!
Lieb
8 REPLIES 8
Message 2 of 9
troma
in reply to: Lieblaw
I'm not sure if you mean the whole right-click menu is gone, or just some items are missing from it.
If it's the whole mene, type OP for options, go to the User Preferences tab and check "Shortcut menus in drawing area"
If it's some items missing I think you can edit that in the CUI, but I've never done it.
Mark Green
Working on Civil 3D in Canada
Message 3 of 9
Jeff_M
Make sure your PICKFIRST sysvar is set to 1.
Message 4 of 9
sally.butler
"Options"
Under your options, selection tab, under selections modes make sure the "Noun/verb selection" box is checked on.
Hope this works for you.
SallyB
Message 5 of 9
AllenJessup
Try some of THESE
Allen Jessup
Allen Jessup
CAD Manager - Designer
Message 6 of 9
Lieblaw
The dang Noun/Verb check box!  Thank you gurus for the quick help!
Message 7 of 9
antoniovinci
You should only thank Jeff, because the Pickfirst advice is equivalent of the Noun/Verb one...
Message 8 of 9
in reply to: sally.butler
Never had that happen before. Easy fix when you know the right question and ask the right people.
Thanks for the solution.
Truly,
Message 9 of 9
in reply to: Jeff_M
thank you!!!
Rail Community
