I have an old AutoCAD R12 (not 2012) .dwg with polylines that have elevations on them. I have forgotten how to turn these into contour lines and build a surface out of them in 2013. I know this used to be an easy thing to do. I don't want to use the points or set up point groups in the drawing because these polylines are exactly how I want my surface to look. I need to do a plan and profile from this surface.
Thanks in advance,
Kim
Solved by tcorey. Go to Solution.
Hello Kim,
Create a new surface. It will be blank with no data in it.
On the Prospector tab of Toolspace, expand Surfaces, expand your new surface, expand Definition, right click Contours and pick Add...
Best regards,
Tim
Off the top of my head I'd either convert them to Featurelines and add those to the Surface as breaklines. Or you could explode them and add them as lines.
Allen
Allen Jessup
CAD Manager - Designer
Learned something new. I never realized you could add polylines as contours.
Allen
from my nook tablet
Allen Jessup
This is what I figured out. Thanks Tim! Thanks to everyone else who sent suggestions. I have a couple different ways to do this now.
Just a suggestion to keep drawing size down.... Run the polylines through 'Drawing Cleanup' before you add them to a surface. Often, contours/polylines from old drawings have a ton of vertices not needed. If you run them through drawing cleanup first using simplify objects, delete duplicates and weed polylines, your surface will be cleaner and drawing size will be less. If you do this, delete duplicates should be done first. Simplify and weeding should be done individually - not together as a group. Be careful with Simplify objects, because I've seen contours change shape a few times for whatever reason. The 'weeding polylines' alone will benefit your file size.
