Civil 3D Forum
I have a problem with civil 3D 2013+SP1
6 REPLIES 6
joantopo
612 Views, 6 Replies
No labels about section data (section views) are displayed. The marks appears.
I import band set, all layers are activated,..
With v2012 I didn´t have this problem. In the drawing appears the labels of section data in the section views.
If I open a drawing made with V2012 in C3D 2013, those labels are displayed.
Other problem is that I can´t import styles about band set o styles data section from section view. The program say me that it can´t import those styles!!  And two drawings have been made with v2013.
I have reinstalled the program(C3D 2013 with SP1) again and the problem continue.
It´s a bug of version 2013?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
6 REPLIES 6
tcorey
in reply to: joantopo
Post your drawing and let one of us try it out on our 2013 with SP1.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
joantopo
I've found that if we use this style as default style then displays correctly.
With the command "create multiple sectionview" indicate the band set style.
Try to import styles. The styles band set or data section can´t be imported.
joantopo
Nobody has seen the drawing?
I can´t show the labels (data section)
Jeff_M
Even though the "Weeding" property has been shown in the Sectionview Bands for a number of releases, it was not used when displaying the bands until C3D2013. Your Band style has the weeding factor set to 100, changing this to 0 allows the data to display. You didn't see this issue in C3D2012 since this factor was ignored.
Not sure about the inability to import the band style or band set, looks like I can import to your drawing, and also import into another drawing from yours.
Jeff_M, also a frequent Swamper
joantopo
if I put the weeding factor set to 0, the labels still do not see them.
Jeff_M
Changing the Band Set Style will not update existing sectionviews. Recreate the sectionviews and you will see them updated.
Rail Community
