AutoCAD Civil 3D General
Message 1 of 2 (198 Views)
I can not create Slope Stake Reports
198 Views, 1 Replies
07-22-2011 09:39 AM
 I'm trying to generate these reports, but the C3D 2012 does not generate at all. An error window appears with the text "The value station is out of range." And when I click on "Create Report" nothing happens ...
Someone is going through this?
Felipe Schulz
Twitter:
http://www.twitter.com/felipeschulz
LinkedIn:
http://br.linkedin.com/in/felipeschulz
Active Member
Wanita17
Message 2 of 2 (126 Views)
Re: I can not create Slope Stake Reports
11-16-2011 02:31 PM in reply to: felipeschulz
I am having the same problem with C3D 2012.  I have an alignment with a negative start station that I am unable to create a report for, I think this may be part of the problem because all my alignments that start at 0+000 have no problems with reports.  Did you ever get this issue solved?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
