How to specify the deflection angle while plotting the horizontal alignment?
I’m wondering if there is a way to provide the deflection angle while plotting the horizontal alignment (based on the tangent-tangent with curve method).
Thank you
Best
Jamal
Solved by DaveM. Go to Solution.
I beleive you are looking for this transparent command It can also be invoked by bressing" 'dd " during a comand. If you need more information just ask.
Many thanks Dave. It works fine. Now I could specify the deflection angle while digitizing.
Best
Jamal
