Civil 3D Forum
How to show slope/grade on my surface ? or either on corridor ?
10 REPLIES 10
Message 1 of 11
Aistis88
4969 Views, 10 Replies
Hello , i was wondering is it possible  to show slopes  or grades on my surfaces  , or corridors  IN PLAN VIEW ? Thank you for the help you provide :))
10 REPLIES 10
Message 2 of 11
ericcollins6932
in reply to: Aistis88
Sure, use surface labels underthe Annotate tab/Add Labels/Surface/Surface labels.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 3 of 11
sboon
in reply to: ericcollins6932
You can also use the tools in the Analysis tab of your surface properties dialog to display slopes using a range of colors, or you can display slope arrows showing the range of grades and direction of flow for the TIN.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 4 of 11
Joe-Bouza
You could get a 100 different answers to that question. Are you looking for surface slope value? >>ericcollins6932. surface direction?>>sboon Profile grade line>> add a component to your alignment label style that refs the profile.
Your Name
Message 5 of 11
sboon
in reply to: Joe-Bouza
OK now there's a challenge!  How many possible ways can we find to display a representation of slope/grade in plan view?
Steve
Steve
Message 6 of 11
Joe-Bouza
in reply to: sboon
Well 3 down 97 more to go. You're our cooridor guru Steve can it be done with code set style? <G>
* Banding
....Ok maybe I was tad over zealous <G>
Your Name
Message 7 of 11
sboon
First one using a code set.
The Daylight_Cut and Daylight_Fill links have a Material Area Fill style applied to them.  Those styles show a green dot hatch for fill slopes and a red one for cuts.
Steve
Steve
Message 8 of 11
sboon
in reply to: sboon
Second one using a code set:
In this one the daylight links are colored instead of using a hatch.  I use this code set all the time when I'm designing because it provides an instant reference for where the corridor is in relation to the surface, without looking at sections.  Makes it easy to see where I need to adjust the profile.
Steve
Steve
Message 9 of 11
Joe-Bouza
in reply to: sboon
Very nice. I'm imspired to work with my codes more
Your Name
Message 10 of 11
innov8rdi
in reply to: sboon
sboon - how do you change the color of the site for different slopes?  I can't get to the analysis tool you mentioned to do this and it's exactly what I am looking for today...
Thank you!
Message 11 of 11
neilyj666
in reply to: sboon
I like this method of seeing the cut and fill areas
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
