I need to create a profile view that starts at Station 189+00 and ends at Station 175+00 such that the stationing of the profile decends from left to right. How do I do this in Civil 3D 2010?
Solved by KW-EGA. Go to Solution.
I found what I needed. Under the summary tab in the profile view style there is the option to switch the view direction from left to right.
All of my slope labels have the opposite sign now. Is there an easy way to fix that or do I need to create an expression?
Yes, the slope direction would be correct. I guess I am trying to recreate a plan sheet that is incorrect. I decided to leave the slope signage as assigned by Civil 3D.
right click on profile and go to profile view style, and in graph option change the profile view direction
So how do you flip one profile but not all the others? I have a large drawing with 3 separate profiles. When I flip one, all of them flip. I only want one flipped...to match my stationing. Thanks.
Use a different profile STYLE. or Just copy your existing profile style and rename it.
