Civil 3D Forum
How to open vehicle tracking add on?
4 REPLIES 4
dslocum
6711 Views, 4 Replies
I downloaded the 2015 trial version of Autodesk Vehicle Tracking. After a successful install, I expected to see it on my ribbon in Civil 3D 2014. However, it isn't there and there is no evidence of the install inside Civil 3D. How do I load the program? I have a stand alone license of Civil 3D 2014 and read in the forums that the trial version of Vehicle Tracking is also stand alone. Any help would be appreciated.
4 REPLIES 4
AlmasSuljevic
in reply to: dslocum
I think that the licensing combination (Civil 3D standalone and AVT trial is supported) but the issue is that you have 2014 version of AutoCAD and trial version of AVT 2015. According to readme you need to have 2014 version of AutoCAD or 2014 version of trial AVT.
If you happen to have Civil 3D 2015 and cannot see your ribbon with AVT tools try this:
  1. Enter CUILOAD in the command line and browse to the following location:
  2. C:\Users\<users>\AppData\Roaming\Autodesk\Vehicle Tracking\Menus
  3. Select atrc200.cuix and click Open
  4. Click Load and Close
Most likely you would have to look for Autodesk Vehicle Tracking 2014 trial version.  See this: http://www.autodesk.com/products/vehicle-tracking/free-trial
I hope this helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Shahparnia
in reply to: AlmasSuljevic
My folder that contains CUI file (C:\Users\<users>\AppData\Roaming\Autodesk\Vehicle Tracking\Menus) is empty, any thoughts?
neilyj666
in reply to: Shahparnia
A bit more info would be useful.....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
I have same problem and i tried the solution recommended here.
I tried netload but nothing in the Vehicle tracking menus folder. It's empty. I can't find the xcuix file!! Where else can i find it ?
Thanks in advance.
Rail Community
