Hello every body!
i want to make a multicolored polyline with all the function, i try to use MLSTYLE command but it dont help so much because i can not draw a curve or i can not add vertex after the draw , any another suggestion.
thanks
Solved by AllenJessup. Go to Solution.
thank you for response
i need to draw a polyline consist of two colors Instead of one color is there is any way to do that direct from polyline command?
i try to use MLINE command and it seems good but the polyline was without curves .
I just want to create style for a polyline that instead of one color i can choose two colors without explode it or offset it,
i tried MLSTYLE commande but it wasnt so good .
is anybody tried another method ?
AFAIK that's not possible. If you set WHIPARC to 1. All of the arcs will plot the layer color and the lines will take the color from the plot style. But that effects every single polyline and isn't what you're looking for. It looks like (to me) that you'll have to stick with your workaround.
There may be something that could be done with a non-lightweight polyline with some programming. But that's way past me.
Allen Jessup
Allen Jessup
CAD Manager - Designer
johnm wrote:
You gonna' share?
Well, I belong to the "old school", sorry.
I mean that in this current life I'm (still) hetero, Johnny.
In the next one, who knows..?
Only asking because I'm impressed with the CAD work. I'm just a geek. 🙂
John Mayo
All right, JM, I was joking...
Now check this out (I used my national flag's colours) closer to the OP request:
I attached the .DWG file, now you can guess how I did it: have fun !
190 something objects. I thought you had something real geeky up your sleeve. 😉
Here is a 3 object version that is still not what the OP needs but the inner geek is getting out. 🙂
John Mayo
Your continuous rail on background is a winning idea, Joe.
Get an advice: before you share a DWG with others, please purge it, because of the bunch of unused SHX files.
Maybe not with a polyline but two alignment styles and a zero offset alignment can accomplish this
Joe Bouza
