How to label the curve with its degree of curvature (Da)?
Degree of curvature (Da) can be calculated based on two different ways
Arc definition (considering 30 meters arc length):
Da=1719.74/R
Chord definition (considering 30 meters chord length):
Da=ASIN(50/Radius)*2
The issue here is that there is not built in option to label the curve with its degree of curvature
How this might be accomplished?
Thank you
Best
Jamal
Solved by BrianHailey. Go to Solution.
Many thanks Jeff for the help. Very much appreciated for the screenshots.
I couldn’t find “General segment curve radius”.
Please, have a look on the attached screenshots. Am I in the correct place?
The one I showed was for the General Curve label style expressions. For the Alignment, use the Radius property for the curve. PI's don't necessarily define a curve so you won't be able to include curve information in a PI label, must use a curve label.
Thank you Jeff for the prompt help,
I’ve created a style and labeled with it but sounds that the result is not correct.
The expected value is assumed to be 1719.74/R. R is given as 66.7 while 1719.74/66.7 is supposed to be 26.
When labeling, the angle is as shown in the attached screenshots
What might be the issue then?
Just add the degree of curvature to your label. It's a standard property now.
If you want to change the length used in the calculation, it's in your drawing/feature/command settings.
Many thanks Brian for the help. This is great that this property is built in (attached). Many thanks Jeff for the massive support. Best Jamal
May I know what is the difference between setting the length of the chord to 30m. and 20m.?
