Civil 3D Forum
How to label the curve with its degree of curvature (Da)?
12 REPLIES 12
Message 1 of 13
JamaL9722060
4188 Views, 12 Replies
Degree of curvature (Da) can be calculated based on two different ways
Arc definition (considering 30 meters arc length):
Da=1719.74/R
Chord definition (considering 30 meters chord length):
Da=ASIN(50/Radius)*2
The issue here is that there is not built in option to label the curve with its degree of curvature
How this might be accomplished?
Thank you
Best
Jamal
Jamal Numan
12 REPLIES 12
Message 2 of 13
Jeff_M
in reply to: JamaL9722060
Create expressions, as you have read in other posts. Under the General Curve Labels and/or the Alignment curve labels create an expression for the type of DoC label you wish to use:
Then use the exprssion in the label style:
Message 3 of 13
Jeff_M
in reply to: Jeff_M
Actually, it looks like your Chord formula is for a 100 unit chord, so append *0.30 to the end of the chord expression. The Arc definition expression looks suspect as well....
Message 4 of 13
Jeff_M
in reply to: Jeff_M
This is the expression needed for a 100 unit arc length:
DEG2RAD(5729.58/{General Segment Curve Radius})
Multiply the 5729.58 by 0.30 for a 30 unit arc length
Message 5 of 13
JamaL9722060
in reply to: Jeff_M
Many thanks Jeff for the help. Very much appreciated for the screenshots.
I couldn’t find “General segment curve radius”.
Please, have a look on the attached screenshots. Am I in the correct place?
Jamal Numan
Message 6 of 13
Jeff_M
The one I showed was for the General Curve label style expressions. For the Alignment, use the Radius property for the curve. PI's don't necessarily define a curve so you won't be able to include curve information in a PI label, must use a curve label.
Message 7 of 13
JamaL9722060
in reply to: Jeff_M
Thank you Jeff for the prompt help,
I’ve created a style and labeled with it but sounds that the result is not correct.
The expected value is assumed to be 1719.74/R. R is given as 66.7 while 1719.74/66.7 is supposed to be 26.
When labeling, the angle is as shown in the attached screenshots
What might be the issue then?
Jamal Numan
Message 8 of 13
Jeff_M
Look back at message number 4 that I posted. In the Expression, the returned value must be converted from Degrees to Radians, as C3D's labels use Radians and then converts it to whatever format you want displayed.
Message 9 of 13
BrianHailey
Just add the degree of curvature to your label. It's a standard property now.
If you want to change the length used in the calculation, it's in your drawing/feature/command settings.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 13
Jeff_M
in reply to: BrianHailey
Now why didn't I see that in one of Jamal's images??? Guess I need to spend more time with the newer version(s).
Message 11 of 13
JamaL9722060
Many thanks Brian for the help. This is great that this property is built in (attached). Many thanks Jeff for the massive support. Best Jamal
Jamal Numan
Message 12 of 13
May I know what is the difference between setting the length of the chord to 30m. and 20m.?
Message 13 of 13
BrianHailey
Taken from the Wikipedia entry for Degree of Curvature:
2018-10-17_0833
GEI Consultants
My Civil 3D Blog
Rail Community
