Civil 3D Forum
How to label a part of an arc
5 REPLIES 5
dwcouch123
535 Views, 5 Replies
I have C3D 2012.  I want to label a part of an arc.  The arc has 3 lines that intersect it.  I want to label the overall arc and the pieces of the arc.  The overall arc is not a problem.  How can I label the parts of the arc without breaking it up??
Dave
5 REPLIES 5
Joe-Bouza
in reply to: dwcouch123
4 parcels should do that, but seems like a lot of effort for the return
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
BrianHailey
The best thing I can think of is to copy and break and label. You could use parcels and have parcel segments connect to the arc and then do a spanning label on the one side (entire length) and regular labels on the other side (individual pieces) but that seems like a lot of extra effort if these aren't already parcel segments.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Neilw_05
If you insert elevation points on the arc the labels can apply to the pieces between the elevation points. Likewise if lines in the same site intersect the arc.
Is there some reason that doesn't work guys?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
AllenJessup
Well.... You really can't without breaking it up. Might be able to in 2014. In 2013 you can label lines by points.
What I usually do is copy the arc to a no plot layer or give a copy a no plot color. Then break it in to the segments I want to label. You just have to redefine each arc if there is a change in the overall.
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Neilw_05
http://screencast.com/t/jRYiQAGTQW
WIN 10 64 PRO
Rail Community
