Based on previous posts I am aware that some of you use 3d polys & feature
lines to touch up and even revise surfaces created from corridor models. I
was hoping for a little input, some of the in & outs of the procedures used.
Do you use Snapshots, do you make a copy the corridor surface to edit, how
is it working Feature Lines to really fine tune the grading? What advantages
do Feature lines provide over 3d polys besides a tabular elevation editor? I
ask the last question because it seems most of the Feature line edit
commands work on 3d polys.
I don't seem to be having a great deal of luck with feature lines created
from complex 2d plines (when two arcs in a pline a filleted) and I am also
seeing that the corridor surface is not fully recognizing the breaklines.
See attached. The magenta 3d poly line was added to the surface as a
breakline to transition the typical 2% grade behind a curb. Note that some
of the triangles are doing the Limbo under the breakline. I get the same
results with a Feature Line.
Any and all input is always appreciated,
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
