Hello,,,everybody...
i confused with my desain,,,how to fixed cross line in my design corridors,,
i will calculate,,,cut & fill in my design. i creating location with mudhole,,with definite elevasi,,in +13.80
this design will be creating with terrace so as not to landslide,,
process :
i create future line with elevasi +13.80 & +13.30
end then make a grading group , make grading creation tool for make mudhole, end then create grading infill,,
i creating alignment,,profile, and assembly and then creating the corridors
file attachment
Solved by yohanesseto_a_w. Go to Solution.
Solved by doni49. Go to Solution.
"A pictures worth a thousand words." Can you post a screen shot of what you are seeing? Also a sketch of what you want it to do (created in AutoCAD and/or MSPaint) and upload that.
Don Ireland
Engineering Design Technician
i forgot attach a image...
i want make design such as a that image..
Ok. I'm a little confused. Your title and part of the message indicates that you're looking to do this with corridors. But then in the second image, you say that you want to do it WITHOUT corridors.
You could do what you have in the third image using featurelines (one feature line would represent the top and bottom of each terrace. Then import them all into your surface as breaklines.
Don Ireland
P.S. Here's a quick sample showing a surface created this way. It took less than 5 min to create it this way.
Don Ireland
i am so sorry,,,make you confused,,, thanks you very much your answer really help me,,,
