Hi, I have a question.
I have got a drawing with an alignment containing spiral-curve-spiral entities. I need to find what type of spirals are used in these entities - clothoids, cubic parabolas or other. Is there any way, to find it? In panorama and sub-entity editor there is only spiral description without exact type. Any ideas?
Solved by peterfunkautodesk. Go to Solution.
In the "Alignment Grid View" also know as the "Panorama" view, there is a column for "Spiral Definition" that is off by default. If you right click on a column headling you can check that on and you will see the type of spiral that is used.
Cheers,
Peter Funk
Autodesk, Inc.
