When we create Civil plans for our projects we always keep separate model files for the survey, demolition plan, site plan, utility plan , & grading plan, etc. When then X-Ref these drawings together in various combinations together to create our sheets (layouts). I assume most civil engineering firms follow this practice.
When don't have a survey department, so our topographic survey drawings come from various companies. Lately we have been receiving survey files created with Civil 3D. Most all the time the survey point symbols and the label styles are on the same layer. When we reference the survey files in our various sheets we do not have the ability to "turn off" the point labels as needed.
I have searched this group trying to find solution to this problem. Most of the replies talk about using point groups and a label styles to control visibility. How can this be done when the drawing files are X-Referenced? Plus, other disciplines are X-Referencing the Survey files as well, and only have plain AutoCad with the Object-Enabler loaded. On top of all this, most of the survey point symbols are blocks that have a color assigned to them, preventing them to be "gray scaled" in thru the X-Reference.
The only way I have resolved these problems are to redefine the blocks and label styles within the Survey file. Unless I am missing something on how Civil 3D works, I guess I need to make sure the surveying firm creates the point & labels styles on separate layers and define the all block colors to either "bylayer" or "byblock"?
Paul
C3d 2010
If it is not our survey work we ask for an xml file of the surface and 2d linework and text for the property and topographic surveys. We do not request or need their point objects specifically if we get the surface, syms and text labels.
John Mayo
That's nice, I was commenting for others sake who use these forums as a reference to finding solutions for potential issues.
The focus should be on what your subject line indicates, not a sub-topic that was introduced halfway though. Partially my fault for commenting on other's comments vs. sticking to what my main question is, and that's the visibility of points and point labels through and XREF. Maybe it's best to open a new thread since we're off on a major tangent.
Major tangents, wait that's my job description. Sorry.... couldn't resist.
As many have stated, get your DWT setup the way you want it to function. During your contract negotiations with the surveyor indicate in writing what they need to provide. If they do not provide the product per the contract send it back. After all, they are working for you. You should not have to manipulate the data in any way beyond cosmetic layering changes so the survey data shows up correctly in your design product.
With that said, we have our own in house surveying (me) that sets up our survey data, labels, styles, etc..... In civil3d we have a text layer and a point layer for each description code this allows us to freeze the text or symbols independently of each other.
My 2 cents....
I'm not exactly sure how extensive your surveys are.
If you're dealing with an existing site survey, with above and below ground locates, combined with a road survey... You're talking upwards of at least a 150 possible point descriptions and having a layer for both "point-description" and "point label-description" is not going to happen. High probability your drawing file would even open at that point.
Off topic, but that's precisely the type of work we do, our DWT has 517 layers all with appropriate filters to quickly turn things off and on. You may have misunderstood.....we have a separate "SYMB" layer for each code that requies a symbol. This is controlled by the description key set and then a separate "TEXT" layer that contains the point number, elevation and code' which is controlled by the label style. It works just fine and allows much flexibility in displaying points, markers, symbols and text. Working on a site project right now with over 7000 surveyed points.
