AutoCAD Civil 3D General Discussion
Valued Contributor
John7
Message 1 of 4 (1,627 Views)
How to convert elevation text to points? Civil 3D 2009
1627 Views, 3 Replies
10-30-2009 09:50 AM
Hi
I've got an old survey in which there is only spot elevation text. I have moved the text to its corresponding elevation using "Surface\utilities\move text to elevation".
Great so far.
Now how do I create points from these text entities?
John
*John Mayo
Message 2 of 4 (1,627 Views)
Re: How to convert elevation text to points? Civil 3D 2009
10-30-2009 12:33 PM in reply to: John7
If you need a surface you can add the test strings. You will find the option
when adding Drawing Data to your surface definition.
If you need points I think Terry has a lisp program to do this.
www.dotsoft.com
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB (I do not recommend this card for C3D)
Vista64
Valued Contributor
John7
Message 3 of 4 (1,627 Views)
10-30-2009 01:31 PM in reply to: John7
Got it.
I see its under the surface in the prospector. Under Drawing Objects you can add text, lines whatever.
Thanks again
John
Member
ove.cervin
Message 4 of 4 (1,627 Views)
11-03-2009 05:14 AM in reply to: John7
Hi there,
You can also use the Map Query command to get things like that done.
I posted this yesterday and it will be a follow up tomorrow, presenting how to create the COGO Points from a Report
[Tips on From the Ground Up|http://fromthegroundup.typepad.com/from_the_ground_up/2009/11/text-to-cogo-back-again.html]
// Ove
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
