My data is in decimal format and
In metric I am geting the feet interval of contours
How to change the feet to decimal system
Solved by AllenJessup. Go to Solution.
Solved by el.Topo. Go to Solution.
You have to change it to Meter in the Contour label style. You'll also need to change the precision to the correct decimal places in the minor contour label style. Then you can set your interval to 0.25m or whatever you need. I'd also check your Ambient settings to make sure Metric is the selected format.
BTW. In Civil feet are measured in decimal also. So the issue is Metric vs. Feet not whether it is in decimal or not.
Allen
Allen Jessup
CAD Manager - Designer
Hi there,
try this:
Toolspace - Settings - (Rightclick your project's name) Edit Drawing Settings - Ambient Settings Tab
What you need is to change the Distance property Unit parameter to meter.
SInce you want to work in Metric, check out the rest of the options in the same tab, especially the unit parameter for all Properties.
I have try but fail
Could U pls Change in my file and return the corrected copy
From the image you posted it's clear that it's not a label problem, but a surface option that is based on the settings as I mentioned.
I don't have 2013 installed.
Allen
Allen Jessup
That's true. The label style might be correct while the Ambient settings are wrong. But I bet both are wrong. It looks like this drawing may have been started from an imperial template or at least one that was at one time created from an imperial template.
Allen
Allen Jessup
I want the contours in decimal feet
I have try but it give me the meter not decimal feet
in feet it divided by 12 the value of contours
@ Allan: You guessed right too!
Besides the Ambient settings, the Standard Label Style used to label contours had the text content showing in feet.
I think the OP needs to start from a fresh template. The recent post stating that "in feet it divided by 12 the value of contours" makes me think the Units may be set to Architectural.
Allen
Allen Jessup
