IF YOU ARE USING CIVIL 3D, JUST USE THE MAPIMPOT COMMAD, TO BRING IT INTO YOUR DRAWING. MAKE SURE YOU CHECK CLOSED POLY.
you can also use data connect in the FDO editor, style as desired, then from the tool boxe export to drawing file
Joe Bouza
