Civil 3D Forum
How do I delete a cartogramma?
2 REPLIES 2
311 Views, 2 Replies
I have downloaded and installed the Cartogramma extension for Civil 3D 2012.  It did exactly what I was looking for but now I just have one problem.  How do I get rid of it?  Now that it's created in my drawing it automatically updates every time I rebuild my corridor.  The update takes a significant amount of time to complete and I have to disable my undo log or it will crash Civil 3D.
I've erased all objects that it creates but when it updates everything comes back.  I was going to try to use the "erase cartogramma" function but that allows me to pick one object at a time and I have about 75,000 objects to clear everything out.
I'm sure I can probably uninstall the extension and that would keep it from updating but it is a fairly useful tool so I'd like to learn how to use it properly.
2 REPLIES 2
MikeEvansUK
There is a tool to delete the cartogramma in the same location as create or edit one.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
in reply to: MikeEvansUK
Are you referring to the "erase cartogramma" function listed with Create and Edit?  I tried that but when I select an object within the cartogramma nothing happens, it just keeps asking me to select a cartogramma.  Since the cartogramma is made up of separate objects I have no idea which one of those objects is the "key" object to select.
Rail Community
